<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="476" width="681"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="30"/> <parameter key="number_of_attributes" value="3"/> <parameter key="attributes_lower_bound" value="1.0"/> <parameter key="attributes_upper_bound" value="4.0"/> <parameter key="datamanagement" value="int_array"/> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att1|att2|att3"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="313" y="30"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="customerId"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="447" y="30"> <parameter key="old_name" value="att2"/> <parameter key="new_name" value="ProductID"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (3)" width="90" x="581" y="30"> <parameter key="old_name" value="att3"/> <parameter key="new_name" value="amount"/> </operator> <operator activated="true" breakpoints="after" class="multiply" expanded="true" height="76" name="Multiply" width="90" x="45" y="210"/> <operator activated="true" breakpoints="after" class="aggregate" expanded="true" height="76" name="Aggregate" width="90" x="179" y="210"> <list key="aggregation_attributes"> <parameter key="amount" value="sum"/> </list> <parameter key="group_by_attributes" value="customerId|ProductID"/> </operator> <operator activated="true" class="pivot" expanded="true" height="76" name="Pivot (2)" width="90" x="313" y="210"> <parameter key="group_attribute" value="customerId"/> <parameter key="index_attribute" value="ProductID"/> </operator> <operator activated="true" class="replace_missing_values" expanded="true" height="94" name="Replace Missing Values" width="90" x="514" y="210"> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Rename (3)" to_port="example set input"/> <connect from_op="Rename (3)" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Pivot (2)" to_port="example set input"/> <connect from_op="Pivot (2)" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="180"/> <portSpacing port="sink_result 2" spacing="108"/> </process> </operator></process>
