Starting RM from outside
greyhound
hello,
I want to use RM within other applications. The data feed is a exel sheet wich is renewed every 5 .... 15 minutes.
How can I start the RM-process remotely after the new data is loaded f.e. by time or an extern signal, making the whole
application run automatically.
thanks for suggestions
land
there are several solutions possible. The easiest way for you would be to incorporate a RapidAnalytics Server that can either execute processes all 5 or 15 minutes or simply if you request an URL. Of course it has many more capabilities so it might be a little bit overdone.
Another solution would be to use the RapidMiner API to execute the process from another Java Program. If this does not work, you simply might start RapidMiner and a Process from commandline. This solution looks most improvisational, but might work best for you.
Greetings,
Sebastian
