<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="444" width="828"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="real_to_integer" expanded="true" height="76" name="generate quantity" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="313" y="30"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="Qty"/> </operator> <operator activated="true" class="subprocess" expanded="true" height="76" name="remember empty copy" width="90" x="447" y="30"> <process expanded="true" height="444" width="828"> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="45" y="165"/> <operator activated="true" class="filter_examples" expanded="true" height="76" name="Mustn't match any" width="90" x="179" y="300"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="Qty=-1"/> </operator> <operator activated="true" class="remember" expanded="true" height="60" name="Remember" width="90" x="313" y="300"> <parameter key="name" value="Result"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_port="in 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Mustn't match any" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_port="out 1"/> <connect from_op="Mustn't match any" from_port="example set output" to_op="Remember" to_port="store"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_examples" expanded="true" height="76" name="Loop Examples" width="90" x="581" y="30"> <process expanded="true" height="444" width="828"> <operator activated="true" class="extract_macro" expanded="true" height="60" name="Extract Macro" width="90" x="112" y="165"> <parameter key="macro" value="QuantityDouble"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Qty"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="generate_macro" expanded="true" height="76" name="Generate Macro" width="90" x="246" y="165"> <list key="function_descriptions"> <parameter key="Quantity" value="round(%{QuantityDouble})"/> </list> </operator> <operator activated="true" class="filter_example_range" expanded="true" height="76" name="Filter Example Range" width="90" x="246" y="30"> <parameter key="first_example" value="%{example}"/> <parameter key="last_example" value="%{example}"/> </operator> <operator activated="true" class="loop" expanded="true" height="76" name="Loop" width="90" x="380" y="30"> <parameter key="iterations" value="%{Quantity}"/> <process expanded="true" height="444" width="828"> <operator activated="true" class="recall" expanded="true" height="60" name="Recall" width="90" x="112" y="120"> <parameter key="name" value="Result"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="append" expanded="true" height="94" name="Append" width="90" x="313" y="30"/> <operator activated="true" class="remember" expanded="true" height="60" name="Remember (2)" width="90" x="525" y="131"> <parameter key="name" value="Result"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_port="input 1" to_op="Append" to_port="example set 1"/> <connect from_op="Recall" from_port="result" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Loop" to_port="input 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <operator activated="true" class="recall" expanded="true" height="60" name="Recall (2)" width="90" x="581" y="120"> <parameter key="name" value="Result"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="generate quantity" to_port="example set input"/> <connect from_op="generate quantity" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="remember empty copy" to_port="in 1"/> <connect from_op="remember empty copy" from_port="out 1" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <connect from_op="Recall (2)" from_port="result" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
