<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="550" width="681"> <operator activated="true" class="retrieve" expanded="true" height="60" name="test data" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Samples/data/Golf-Testset"/> </operator> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="8" y="69"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="179" y="30"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="179" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" expanded="true" height="76" name="Performance" width="90" x="246" y="300"> <list key="class_weights"/> </operator> <operator activated="true" class="performance_classification" expanded="true" height="76" name="Performance (2)" width="90" x="258" y="426"> <list key="class_weights"/> </operator> <operator activated="true" class="average" expanded="true" height="94" name="Average" width="90" x="581" y="255"/> <connect from_op="test data" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Retrieve" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="result 1"/> <connect from_op="Performance" from_port="performance" to_op="Average" to_port="averagable 1"/> <connect from_op="Performance" from_port="example set" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Average" to_port="averagable 2"/> <connect from_op="Average" from_port="average" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
