<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="572" width="681"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"> <parameter key="create_nominal_ids" value="true"/> </operator> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="313" y="30"/> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Temperature|id"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="series:moving_average" expanded="true" height="76" name="Moving Average" width="90" x="45" y="165"> <parameter key="attribute_name" value="Temperature"/> </operator> <operator activated="true" class="series:moving_average" expanded="true" height="76" name="Moving Average (3)" width="90" x="179" y="165"> <parameter key="attribute_name" value="moving_average(Temperature)"/> <parameter key="window_width" value="4"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="45" y="300"> <parameter key="old_name" value="moving_average(Temperature)"/> <parameter key="new_name" value="MA_Fast"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="179" y="300"> <parameter key="old_name" value="moving_average(moving_average(Temperature))"/> <parameter key="new_name" value="MA_Slow"/> </operator> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="300"> <list key="function_descriptions"> <parameter key="larger" value="if (MA_Fast > MA_Slow, 1, 0) "/> </list> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes (2)" width="90" x="447" y="300"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="id|larger"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="materialize_data" expanded="true" height="76" name="Materialize Data" width="90" x="45" y="435"/> <operator activated="true" class="series:windowing" expanded="true" height="76" name="Windowing" width="90" x="179" y="435"> <parameter key="window_size" value="2"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (3)" width="90" x="313" y="435"> <parameter key="old_name" value="larger-0"/> <parameter key="new_name" value="first"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (4)" width="90" x="447" y="435"> <parameter key="old_name" value="larger-1"/> <parameter key="new_name" value="second"/> </operator> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="581" y="435"> <list key="function_descriptions"> <parameter key="crossing" value="first != second"/> </list> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="581" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Join" to_port="left"/> <connect from_op="Multiply" from_port="output 2" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Moving Average" to_port="example set input"/> <connect from_op="Moving Average" from_port="example set output" to_op="Moving Average (3)" to_port="example set input"/> <connect from_op="Moving Average (3)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Materialize Data" to_port="example set input"/> <connect from_op="Materialize Data" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Rename (3)" to_port="example set input"/> <connect from_op="Rename (3)" from_port="example set output" to_op="Rename (4)" to_port="example set input"/> <connect from_op="Rename (4)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="414"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
