<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <parameter key="logverbosity" value="warning"/> <process expanded="true" height="386" width="909"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="subprocess" expanded="true" height="76" name="Preprocessing" width="90" x="180" y="30"> <process expanded="true" height="385" width="909"> <operator activated="true" class="discretize_by_frequency" expanded="true" height="94" name="FrequencyDiscretization" width="90" x="45" y="30"> <parameter key="number_of_bins" value="5"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="nominal_to_binominal" expanded="true" height="94" name="Nominal2Binominal" width="90" x="477" y="30"> <parameter key="transform_binominal" value="true"/> </operator> <connect from_port="in 1" to_op="FrequencyDiscretization" to_port="example set input"/> <connect from_op="FrequencyDiscretization" from_port="example set output" to_op="Nominal2Binominal" to_port="example set input"/> <connect from_op="Nominal2Binominal" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="fp_growth" expanded="true" height="76" name="FPGrowth" width="90" x="313" y="30"> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="min_support" value="0.1"/> </operator> <operator activated="true" class="create_association_rules" expanded="true" height="60" name="AssociationRuleGenerator" width="90" x="313" y="165"> <parameter key="min_confidence" value="0.7"/> </operator> <operator activated="true" class="execute_script" expanded="true" height="76" name="Execute Script" width="90" x="447" y="255"> <parameter key="script" value="import com.rapidminer.tools.Ontology; import com.rapidminer.operator.learner.associations.*; AssociationRules rules = input[0]; // construct attribute set Attribute[] attributes= new Attribute[11]; attributes[0] = AttributeFactory.createAttribute("Premise", Ontology.STRING); attributes[1] = AttributeFactory.createAttribute("Premise Items", Ontology.INTEGER); attributes[2] = AttributeFactory.createAttribute("Conclusion", Ontology.STRING); attributes[3] = AttributeFactory.createAttribute("Conclusion Items", Ontology.INTEGER); attributes[4] = AttributeFactory.createAttribute("Confidence", Ontology.REAL); attributes[5] = AttributeFactory.createAttribute("Conviction", Ontology.REAL); attributes[6] = AttributeFactory.createAttribute("Gain", Ontology.REAL); attributes[7] = AttributeFactory.createAttribute("Laplace", Ontology.REAL); attributes[8] = AttributeFactory.createAttribute("Lift", Ontology.REAL); attributes[9] = AttributeFactory.createAttribute("Ps", Ontology.REAL); attributes[10] = AttributeFactory.createAttribute("Total Support", Ontology.REAL); MemoryExampleTable table = new MemoryExampleTable(attributes); DataRowFactory ROW_FACTORY = new DataRowFactory(0); String[] strings= new String[11]; for (AssociationRule rule : rules) { 		// construct example data strings[0]=rule.toPremiseString(); strings[1]=rule.premise.size().toString(); strings[2]=rule.toConclusionString(); strings[3]=rule.conclusion.size().toString(); strings[4]=rule.getConfidence().toString(); strings[5]=rule.getConviction().toString(); strings[6]=rule.getGain().toString(); strings[7]=rule.getLaplace().toString(); strings[8]=rule.getLift().toString(); strings[9]=rule.getPs().toString(); strings[10]=rule.getTotalSupport().toString(); // make and add row DataRow row = ROW_FACTORY.create(strings, attributes); table.addDataRow(row);	 		} ExampleSet exampleSet = table.createExampleSet(); return exampleSet; "/> </operator> <operator activated="true" class="replace_infinite_values" expanded="true" height="94" name="Replace Infinite Values" width="90" x="581" y="165"> <list key="columns"/> </operator> <operator activated="true" class="write_database" expanded="true" height="60" name="Write Database" width="90" x="715" y="75"> <parameter key="connection" value="CJFP"/> <parameter key="table_name" value="testo"/> <parameter key="overwrite_mode" value="overwrite first, append then"/> <parameter key="set_default_varchar_length" value="true"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Preprocessing" to_port="in 1"/> <connect from_op="Preprocessing" from_port="out 1" to_op="FPGrowth" to_port="example set"/> <connect from_op="FPGrowth" from_port="frequent sets" to_op="AssociationRuleGenerator" to_port="item sets"/> <connect from_op="AssociationRuleGenerator" from_port="rules" to_op="Execute Script" to_port="input 1"/> <connect from_op="Execute Script" from_port="output 1" to_op="Replace Infinite Values" to_port="example set input"/> <connect from_op="Replace Infinite Values" from_port="example set output" to_op="Write Database" to_port="input"/> <connect from_op="Write Database" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
