<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="370" width="614"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Training Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_data" expanded="true" height="60" name="Score Data" width="90" x="112" y="255"/> <operator activated="true" class="linear_regression" expanded="true" height="76" name="Linear Regression" width="90" x="246" y="30"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="514" y="30"> <list key="application_parameters"/> </operator> <connect from_op="Training Data" from_port="output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Score Data" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Linear Regression" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <process expanded="true" height="460" width="966"> <operator activated="true" class="read_csv" expanded="true" height="60" name="CSVExampleSource" width="90" x="45" y="30"/> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="180" y="30"> <parameter key="name" value="TARGET_LABEL"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="sample_bootstrapping" expanded="true" height="76" name="Bootstrapping" width="90" x="315" y="30"/> <operator activated="true" class="nominal_to_numerical" expanded="true" height="94" name="Nominal2Numerical" width="90" x="450" y="30"/> <operator activated="true" class="x_validation" expanded="true" height="112" name="XValidation" width="90" x="585" y="30"> <process expanded="true" height="460" width="458"> <operator activated="true" class="adaboost" expanded="true" height="76" name="AdaBoost" width="90" x="45" y="30"> <process expanded="true" height="460" width="966"> <operator activated="true" class="naive_bayes_kernel" expanded="true" height="76" name="KernelNaiveBayes" width="90" x="45" y="30"/> <connect from_port="training set" to_op="KernelNaiveBayes" to_port="training set"/> <connect from_op="KernelNaiveBayes" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <connect from_port="training" to_op="AdaBoost" to_port="training set"/> <connect from_op="AdaBoost" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="460" width="458"> <operator activated="true" class="apply_model" expanded="true" height="76" name="ModelApplier" width="90" x="45" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="true"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="180" y="30"/> <operator activated="true" class="write_as_text" expanded="true" height="76" name="ResultWriter" width="90" x="319" y="30"> <parameter key="result_file" value="G:\Rapping\model_results.csv"/> </operator> <connect from_port="test set" to_op="ModelApplier" to_port="unlabelled data"/> <connect from_op="ModelApplier" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_op="ResultWriter" to_port="input 1"/> <connect from_op="ResultWriter" from_port="input 1" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="read_csv" expanded="true" height="60" name="Score Set" width="90" x="45" y="165"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="782" y="165"> <list key="application_parameters"/> </operator> <connect from_op="CSVExampleSource" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Bootstrapping" to_port="example set input"/> <connect from_op="Bootstrapping" from_port="example set output" to_op="Nominal2Numerical" to_port="example set input"/> <connect from_op="Nominal2Numerical" from_port="example set output" to_op="XValidation" to_port="training"/> <connect from_op="XValidation" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="XValidation" from_port="averagable 1" to_port="result 1"/> <connect from_op="Score Set" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
