I'm having problem with transfer radioss result of modal analysis (eigenmode) into model in AcuConsole. Animating of radioss result show different scale with model in AcuConsole. Then, when transfer AcuConsole suddenly shutdown.
I'm suspecting the different of default unit used between both solver which cause different scale.
Radios unit:-
kPa
density = tonne/mm^3
AcuConsole unit:-
Pa
density = kg/m^3
Anyone have idea how to solve this?
Can or not rescale radioss result into compatible AcuConsole unit? Or need to run modal analysis with acuconsole unit?
Thanks
