<process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="145" width="279"> <operator activated="true" class="read_database" expanded="true" height="60" name="Read Database" width="90" x="45" y="30"/> <operator activated="true" class="loop_examples" expanded="true" height="76" name="Loop Examples" width="90" x="179" y="30"> <process expanded="true" height="419" width="492"> <operator activated="true" class="extract_macro" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30"> <parameter key="macro" value="table"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="tbl_name"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="read_database" expanded="true" height="60" name="Read Database (2)" width="90" x="179" y="75"> <parameter key="query" value="SELECT * FROM `%{table}`"> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <connect from_op="Read Database (2)" from_port="output" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Read Database" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
