<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="314" width="614"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="246" y="30"/> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="discretize_by_user_specification" expanded="true" height="94" name="Discretize" width="90" x="246" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Humidity"/> <list key="classes"> <parameter key="dry" value="68.0"/> <parameter key="nomal" value="75.0"/> <parameter key="humid" value="Infinity"/> </list> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree (2)" width="90" x="447" y="165"/> <connect from_op="Retrieve" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="result 1"/> <connect from_op="Decision Tree" from_port="exampleSet" to_port="result 2"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Decision Tree (2)" to_port="training set"/> <connect from_op="Decision Tree (2)" from_port="model" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
