<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="449" width="882"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1000"/> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="series:windowing" expanded="true" height="76" name="Windowing" width="90" x="179" y="30"> <parameter key="window_size" value="10"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="name" value="att1-0"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="linear_regression" expanded="true" height="76" name="Linear Regression" width="90" x="447" y="30"/> <operator activated="true" class="select_attributes" expanded="true" height="76" name="remove label" width="90" x="447" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1-0"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="remember" expanded="true" height="60" name="Remember" width="90" x="581" y="210"> <parameter key="name" value="es"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="loop" expanded="true" height="76" name="Loop" width="90" x="715" y="30"> <parameter key="iterations" value="30"/> <process expanded="true" height="460" width="1016"> <operator activated="true" class="recall" expanded="true" height="60" name="Recall" width="90" x="45" y="75"> <parameter key="name" value="es"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="246" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" breakpoints="after" class="loop_attributes" expanded="true" height="60" name="Loop Attributes" width="90" x="380" y="30"> <parameter key="iteration_macro" value="currentAttribute"/> <process expanded="true" height="460" width="966"> <operator activated="true" class="branch" expanded="true" height="76" name="Branch" width="90" x="112" y="30"> <parameter key="condition_type" value="macro_defined"/> <parameter key="condition_value" value="lastAttribute"/> <process expanded="true" height="460" width="480"> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{lastAttribute}"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="179" y="30"> <parameter key="old_name" value="%{currentAttribute}"/> <parameter key="new_name" value="%{lastAttribute}"/> </operator> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="currentAttribute" width="90" x="45" y="165"> <parameter key="macro_name" value="currentAttribute"/> </operator> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="lastAttribute" width="90" x="179" y="165"> <parameter key="macro_name" value="lastAttribute"/> </operator> <operator activated="true" class="log" expanded="true" height="76" name="Log" width="90" x="179" y="300"> <list key="log"> <parameter key="current" value="operator.currentAttribute.value.macro_value"/> <parameter key="last" value="operator.lastAttribute.value.macro_value"/> <parameter key="round" value="operator.Loop Attributes.value.applycount"/> </list> </operator> <operator activated="true" class="set_macro" expanded="true" height="76" name="Set Macro" width="90" x="313" y="300"> <parameter key="macro" value="lastAttribute"/> <parameter key="value" value="%{currentAttribute}"/> </operator> <connect from_port="condition" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="currentAttribute" to_port="through 1"/> <connect from_op="currentAttribute" from_port="through 1" to_op="lastAttribute" to_port="through 1"/> <connect from_op="lastAttribute" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true" height="460" width="458"> <operator activated="true" class="set_macro" expanded="true" height="76" name="Set Macro (2)" width="90" x="313" y="30"> <parameter key="macro" value="lastAttribute"/> <parameter key="value" value="%{currentAttribute}"/> </operator> <connect from_port="condition" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="514" y="30"> <parameter key="name" value="prediction(att1-0)"/> </operator> <operator activated="true" breakpoints="after" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="648" y="30"> <parameter key="old_name" value="prediction(att1-0)"/> <parameter key="new_name" value="att1-1"/> </operator> <operator activated="true" class="remember" expanded="true" height="60" name="Remember (2)" width="90" x="782" y="75"> <parameter key="name" value="es"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_port="input 1" to_op="Apply Model" to_port="model"/> <connect from_op="Recall" from_port="result" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="162"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_op="Loop" to_port="input 1"/> <connect from_op="Linear Regression" from_port="exampleSet" to_op="remove label" to_port="example set input"/> <connect from_op="remove label" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
