> I would like to initiate a project to produce a neural network.
> Training data each instance has 10 parameters, each parameter have value from a pool of 500 non-English phrases. There would be thousands of instances with each instance on a line in Excel.My first thinking is to change these into 500 variables with true/false to show existence of each phrase.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="505" width="949"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1000"/> </operator> <operator activated="true" class="discretize_by_frequency" expanded="true" height="94" name="Discretize" width="90" x="179" y="30"> <parameter key="number_of_bins" value="100"/> </operator> <operator activated="true" class="nominal_to_binominal" expanded="true" height="94" name="Nominal to Binominal" width="90" x="380" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
> I am not sure this is the correct way of thinking, and I am wondering RM can handle this vast amount of parameters. And does RM support non-English text? I believe it is in Unicode (I am not very familiar with this also).
