<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="586" width="366"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="write_csv" expanded="true" height="60" name="Write CSV" width="90" x="179" y="75"> <parameter key="csv_file" value="C:\Users\SebastianLoh\Documents\test.csv"/> </operator> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="45" y="210"> <parameter key="file_name" value="C:\Users\SebastianLoh\Documents\test.csv"/> </operator> <operator activated="true" class="series:moving_average" expanded="true" height="76" name="Moving Average" width="90" x="246" y="210"> <parameter key="attribute_name" value="att1"/> </operator> <operator activated="true" class="series:moving_average" expanded="true" height="76" name="Moving Average (2)" width="90" x="246" y="345"> <parameter key="attribute_name" value="att2"/> </operator> <operator activated="true" class="series:moving_average" expanded="true" height="76" name="Moving Average (3)" width="90" x="246" y="480"> <parameter key="attribute_name" value="att3"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Write CSV" to_port="input"/> <connect from_op="Read CSV" from_port="output" to_op="Moving Average" to_port="example set input"/> <connect from_op="Moving Average" from_port="example set output" to_op="Moving Average (2)" to_port="example set input"/> <connect from_op="Moving Average (2)" from_port="example set output" to_op="Moving Average (3)" to_port="example set input"/> <connect from_op="Moving Average (3)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
