<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="280" width="547"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75"> <parameter key="file_name" value="C:\Documents and Settings\chobo\Desktop\test.csv"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="246" y="97"> <parameter key="name" value="WinLoss"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="380" y="120"/> <connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="583" width="920"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="112" y="210"> <parameter key="file_name" value="C:\Documents and Settings\chobo\Desktop\test.csv"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="313" y="165"> <parameter key="name" value="WinLoss"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="581" y="120"/> <connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="result 1"/> <connect from_op="Decision Tree" from_port="exampleSet" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
