<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="431" width="547"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="31" y="65"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="generate_empty_attribute" expanded="true" height="76" name="create_time" width="90" x="45" y="210"> <parameter key="name" value="time"/> <parameter key="value_type" value="polynominal"/> </operator> <operator activated="true" class="execute_script" expanded="true" height="76" name="set_time_values" width="90" x="179" y="210"> <parameter key="script" value="ExampleSet exampleSet = operator.getInput(ExampleSet.class); int counter = 1; for (Example example : exampleSet) { 	if(Math.pow(-1,counter) == 1){ example["time"] = "08:10AM"; }else{ 	 example["time"] = "08:10PM"; } counter++; } return exampleSet;"/> </operator> <operator activated="true" class="generate_copy" expanded="true" height="76" name="Generate Copy" width="90" x="313" y="210"> <parameter key="attribute_name" value="time"/> <parameter key="new_name" value="transformed_time"/> </operator> <operator activated="true" class="nominal_to_date" expanded="true" height="76" name="Nominal to Date" width="90" x="447" y="75"> <parameter key="attribute_name" value="transformed_time"/> <parameter key="date_type" value="time"/> <parameter key="date_format" value="h:mma"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="create_time" to_port="example set input"/> <connect from_op="create_time" from_port="example set output" to_op="set_time_values" to_port="input 1"/> <connect from_op="set_time_values" from_port="output 1" to_op="Generate Copy" to_port="example set input"/> <connect from_op="Generate Copy" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
a: am/pm marker; Text; example: PM
