<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="673" width="1094"> <operator activated="true" class="web:crawl_web" expanded="true" height="60" name="Crawl Web" width="90" x="109" y="144"> <parameter key="url" value="http://www.aol.com"/> <list key="crawling_rules"> <parameter key="3" value=".*"/> <parameter key="1" value=".*"/> </list> <parameter key="write_pages_into_files" value="false"/> <parameter key="output_dir" value="C:\Users\Martin\Desktop\crawltest"/> <parameter key="max_depth" value="10"/> <parameter key="max_page_size" value="1000"/> </operator> <connect from_op="Crawl Web" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
