Can we convert op2 file result which is in unit (MPa & milimeter) into (Pa & meter)?
Or, must rerun with desired unit?
Thanks
regards
I don't think it is possible to change the units of the results unit system.
You may have to re-run the analysis with the desired unit consistency.
you can use derived results also called result math to easily convert units, just multiply with the conversion factor. read about derived results in HyperView help.
