Hi all,
In acusolve, is there any bc setup for no-slip condition? Or, any bc setup which similar or close to no-slip bc?
Thanks
alpharays
Wall BC has no slip conditions in AcuSolve.
See the doc for airfoil using no-slip/wall BC.
http://www.altairhyperworks.com/%28S%28abosnynyy2lsvkdbzowbzg05%29%29/ResLibDownload.aspx?file_id=1470&from=ResourceLibrary.aspx%3Fkeywords%3DAcuSolve%2BValidation%2B-%2BNACA0012%2BAirfoil
\acusolve\win64\doc\AcuSolve-Command-Reference-Manual.pdf also has description of BCs used in AcuSolve
Hope this solves your issue.
