<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="391" width="915"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="88" y="121"/> <operator activated="true" class="loop_attributes" expanded="true" height="60" name="Loop Attributes" width="90" x="380" y="75"> <process expanded="true" height="391" width="915"> <operator activated="true" class="extract_macro" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="75"> <parameter key="macro" value="atts"/> <parameter key="macro_type" value="number_of_attributes"/> </operator> <operator activated="true" breakpoints="before" class="remove_attribute_range" expanded="true" height="76" name="Remove Attribute Range" width="90" x="380" y="120"> <parameter key="first_attribute" value="%{atts}"/> <parameter key="last_attribute" value="%{atts}"/> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Remove Attribute Range" to_port="example set input"/> <connect from_op="Remove Attribute Range" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
