<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="619" width="947"> <operator activated="true" class="execute_script" expanded="true" height="60" name="Execute Script" width="90" x="200" y="136"> <parameter key="script" value="import org.apache.commons.math.stat.descriptive.DescriptiveStatistics; // Get a DescriptiveStatistics instance DescriptiveStatistics stats = new DescriptiveStatistics(); // Add the data from the array for( int i = 0; i <10 ; i++) { stats.addValue(i); } // Compute some statistics double mean = stats.getMean(); operator.logNote("mean:" + mean);"/> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="309" width="806"> <operator activated="true" class="gs:GroovyScripting" expanded="true" height="60" name="GroovyScripting" width="90" x="78" y="202"> <parameter key="script" value="import org.apache.commons.math.stat.descriptive.DescriptiveStatistics; // Get a DescriptiveStatistics instance DescriptiveStatistics stats = new DescriptiveStatistics(); // Add the data from the array for( int i = 0; i <10 ; i++) { stats.addValue(i); } // Compute some statistics double mean = stats.getMean(); operator.logNote("mean:" + mean);"/> <list key="additional_libraries"> <parameter key="commons-math" value="c:\commons-math-2.1.jar"/> </list> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
