The method getNominalMapping() is not supprted by numeric attributes! You probably tried to execute an operator on anumeric data which is only able to handel nominal values.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <parameter key="logfile" value="C:\AfterRuleAccoss.log"/> <parameter key="resultfile" value="C:\afterRuleAccos.res"/> <process expanded="true" height="404" width="915"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="30" y="53"> <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/> </operator> <operator activated="true" class="replace_missing_values" expanded="true" height="94" name="Replace Missing Values" width="90" x="45" y="297"> <parameter key="attributes" value="duration|wage-inc-1st|wage-inc-2nd|wage-inc-3rd|working-hours|standby-pay|shift-differential|statutory-holidays"/> <list key="columns"/> </operator> <operator activated="true" class="discretize_by_frequency" expanded="true" height="94" name="Discretize" width="90" x="179" y="300"> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="nominal_to_binominal" expanded="true" height="94" name="Nominal to Binominal" width="90" x="380" y="300"> <parameter key="transform_binominal" value="true"/> </operator> <operator activated="true" breakpoints="before,after" class="fp_growth" expanded="true" height="76" name="FP-Growth" width="90" x="581" y="255"/> <operator activated="true" class="create_association_rules" expanded="true" height="60" name="Create Association Rules" width="90" x="726" y="263"/> <operator activated="true" class="write_excel" expanded="true" height="60" name="Write Excel" width="90" x="514" y="30"> <parameter key="excel_file" value="C:\result_afterRMVDiscretizeNom2BinomFPGrowth.xls"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="FP-Growth" to_port="example set"/> <connect from_op="FP-Growth" from_port="example set" to_op="Write Excel" to_port="input"/> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_port="result 2"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
beer,bread,jam,butter,cheese,chips,soda,chocolateTRUE,TRUE,FALSE,TRUE,FALSE,TRUE,FALSE,TRUETRUE,TRUE,TRUE,TRUE,FALSE,FALSE,TRUE,TRUEFALSE,TRUE,TRUE,TRUE,TRUE,FALSE,FALSE,FALSETRUE,TRUE,TRUE,TRUE,FALSE,FALSE,FALSE,FALSEFALSE,FALSE,FALSE,FALSE,TRUE,TRUE,TRUE,FALSEFALSE,TRUE,TRUE,FALSE,FALSE,TRUE,TRUE,TRUETRUE,TRUE,FALSE,FALSE,FALSE,TRUE,FALSE,FALSETRUE,FALSE,FALSE,TRUE,TRUE,FALSE,FALSE,TRUEFALSE,TRUE,TRUE,FALSE,TRUE,TRUE,FALSE,FALSETRUE,TRUE,FALSE,FALSE,FALSE,TRUE,TRUE,TRUETRUE,TRUE,TRUE,FALSE,FALSE,FALSE,TRUE,TRUE
beer=FALSE 4jam=FALSE 5butter=TRUE 5cheese=TRUE 4chips=FALSE 5soda=TRUE 5chocolate=FALSE 5
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <parameter key="logfile" value="C\part1_log.log"/> <parameter key="resultfile" value="C:\part1_res.res"/> <process expanded="true" height="601" width="784"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="68" y="121"> <parameter key="file_name" value="C:\part1_data.csv"/> </operator> <operator activated="true" class="nominal_to_binominal" expanded="true" height="94" name="Nominal to Binominal" width="90" x="246" y="120"/> <operator activated="true" class="weka:W-Apriori" expanded="true" height="60" name="W-Apriori" width="90" x="447" y="165"> <parameter key="C" value="0.6"/> <parameter key="M" value="0.4"/> <parameter key="I" value="true"/> <parameter key="R" value="true"/> <parameter key="V" value="true"/> <parameter key="c" value="1.0"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="W-Apriori" to_port="example set"/> <connect from_op="W-Apriori" from_port="associator" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
