could anyone give me an example how the WeightedPerformanceCreator should be used. Unfortunately, the code below returns "unknown" performance value.
Below I have made an example (which is a part of XValidation) where the default weight is 0.0 and the weight of "accuracy" and "relative_error" were explicitly set to 1.0 resp. 2.0. I do nut undersand why the resulting performance vector returns unknown.
Thank you in advance.
<operator name="ClassificationPerformance (5)" class="ClassificationPerformance">
<parameter key="keep_example_set" value="true"/>
<parameter key="main_criterion" value="relative_error"/>
<parameter key="accuracy" value="true"/>
<parameter key="relative_error" value="true"/>
<parameter key="squared_error" value="true"/>
<parameter key="correlation" value="true"/>
<list key="class_weights">
</list>
<operator name="WeightedPerformanceCreator" class="WeightedPerformanceCreator">
<parameter key="default_weight" value="0.0"/>
<list key="criteria_weights">
<parameter key="accuracy" value="1.0"/>
<parameter key="relative_error" value="2.0"/>
</list>
