<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="391" width="915"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="67" y="106"> <parameter key="repository_entry" value="//SQL Data/Updates"/> </operator> <operator activated="true" class="sample" expanded="true" height="76" name="Sample" width="90" x="246" y="30"/> <operator activated="true" class="write_excel" expanded="true" height="60" name="Write Excel" width="90" x="380" y="120"> <parameter key="excel_file" value="C:\Documents and Settings\Alien\My Documents\test.xls"/> </operator> <operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel" width="90" x="447" y="255"> <parameter key="excel_file" value="C:\Documents and Settings\Alien\My Documents\test.xls"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <connect from_op="Read Excel" from_port="output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
With the date 1/0/1900, excel is referencing a cell without data typed in and gives the base date instead
