Sebastian Land wrote:Hi,unfortunately this isn't currently possible with a built in operator. If you don't have too many attributes, you might make the calculations with the Generate Attributes operator.Why are you going to normalize the complete example this way? The attributes will receive different weights per examples and learning will nearly be impossible.Greetings, Sebastian
