linear regression, confidence limit and forward selection
Hello together,
I'm just beginning with rapid miner on some (for me) well known data, and several questions occur to me.
1. Assume numerical data with one label, on which a regression is performed. Is there a way to give a confidence or prediction interval for each predicted label? And if so, how can I get it?
2.
I am applying forward selection with linear regression as learner two times to a (purely numerical) example set. First time with the inner operators "linear regression -> apply model -> performance" as inner operators for the forward selection, and then with a X-validation in the forward selection. Inside the X-validation I have again linear regression as learner and apply model + performance as testing. The results in the performance vectors are slightly different as I expected, and each "method" produces an example set. The example set coming from the 'X-Validation-branch' does not contain predicted values in contrast to the one coming from the forward selection only with linear regression, although I would say, that the output of both coustructs in the forward selection is the same.
I can craete predicted values through another model application + performance after the X-Validation inside the forward selection, but I fear that this changes the result of the forward selection. What woud be a proper way to get predicted values of both methods?
I would highly appreciate if someone could give me a hint. Thank's in advance.
P.S. additionally the XML code:
<operator activated="true" class="normalize" expanded="true" height="94" name="Normalize" width="90" x="581" y="30"/>
<operator activated="true" class="multiply" expanded="true" height="112" name="Multiply" width="90" x="45" y="300"/>
<operator activated="true" class="optimize_selection_forward" expanded="true" height="94" name="Forward Selection (X-Val)" width="90" x="246" y="390">
<parameter key="stopping_behavior" value="without significant increase"/>
<parameter key="alpha" value="0.01"/>
<process expanded="true" height="542" width="614">
<operator activated="true" class="x_validation" expanded="true" height="112" name="X-Validation" width="90" x="112" y="30">
<process expanded="true">
<operator activated="true" class="linear_regression" expanded="true" height="76" name="Linear Regression (X-Val)" width="90" x="115" y="30"/>
<connect from_port="training" to_op="Linear Regression (X-Val)" to_port="training set"/>
<connect from_op="Linear Regression (X-Val)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (X-Val)" width="90" x="45" y="30">
<operator activated="true" class="performance_regression" expanded="true" height="76" name="Performance (X-Val)" width="90" x="182" y="30">
<parameter key="absolute_error" value="true"/>
<parameter key="relative_error" value="true"/>
<parameter key="relative_error_lenient" value="true"/>
<parameter key="relative_error_strict" value="true"/>
<parameter key="normalized_absolute_error" value="true"/>
<parameter key="root_relative_squared_error" value="true"/>
<parameter key="squared_error" value="true"/>
<parameter key="correlation" value="true"/>
<parameter key="squared_correlation" value="true"/>
<parameter key="prediction_average" value="true"/>
<parameter key="spearman_rho" value="true"/>
<parameter key="kendall_tau" value="true"/>
<connect from_port="model" to_op="Apply Model (X-Val)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (X-Val)" to_port="unlabelled data"/>
<connect from_op="Apply Model (X-Val)" from_port="labelled data" to_op="Performance (X-Val)" to_port="labelled data"/>
<connect from_op="Performance (X-Val)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="example set" to_op="X-Validation" to_port="training"/>
<connect from_op="X-Validation" from_port="averagable 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="true" class="optimize_selection_forward" expanded="true" height="94" name="Forward Selection (Regression)" width="90" x="246" y="255">
<operator activated="true" class="linear_regression" expanded="true" height="76" name="Linear Regression" width="90" x="45" y="30"/>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="179" y="30">
<operator activated="true" class="performance_regression" expanded="true" height="76" name="Performance (2)" width="90" x="313" y="30">
<connect from_port="example set" to_op="Linear Regression" to_port="training set"/>
<connect from_op="Linear Regression" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Linear Regression" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="performance"/>
</process>
<operator activated="false" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="45" y="120">
<operator activated="false" class="linear_regression" expanded="true" height="76" name="Linear Regression (2)" width="90" x="115" y="30"/>
<connect from_port="training" to_op="Linear Regression (2)" to_port="training set"/>
<connect from_op="Linear Regression (2)" from_port="model" to_port="model"/>
</process>
<operator activated="false" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="false" class="performance_regression" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Forward Selection (Regression)" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="Forward Selection (X-Val)" to_port="example set"/>
<connect from_op="Multiply" from_port="output 3" to_port="result 7"/>
<connect from_op="Forward Selection (X-Val)" from_port="example set" to_port="result 4"/>
<connect from_op="Forward Selection (X-Val)" from_port="attribute weights" to_port="result 5"/>
<connect from_op="Forward Selection (X-Val)" from_port="performance" to_port="result 6"/>
<connect from_op="Forward Selection (Regression)" from_port="example set" to_port="result 1"/>
<connect from_op="Forward Selection (Regression)" from_port="attribute weights" to_port="result 2"/>
<connect from_op="Forward Selection (Regression)" from_port="performance" to_port="result 3"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
</process>
