In an effort to replicate the predicted value, I basically perform matrix multiplication with the transposed weight matrix and the attribute value matrix.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <description>For many learning tasks, Support Vector Machines are among the best suited learning schemes.They adapt the idea of structural risk minimization and allows for non-linear generalizations with help of kernel functions.</description> <process expanded="true" height="391" width="915"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="support_vector_machine" expanded="true" height="112" name="SVM" width="90" x="179" y="75"/> <operator activated="true" class="create_formula" expanded="true" height="76" name="Create Formula" width="90" x="313" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_op="Create Formula" to_port="model"/> <connect from_op="SVM" from_port="estimated performance" to_port="result 3"/> <connect from_op="Create Formula" from_port="formula" to_port="result 1"/> <connect from_op="Create Formula" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <parameter key="random_seed" value="1976"/> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="758" width="882"> <operator activated="true" class="read_database" expanded="true" height="60" name="Read Database" width="90" x="45" y="30"> <parameter key="connection" value="DataWarehouse"/> <parameter key="query" value="blah"> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="45" y="255"> <parameter key="name" value="NET_PROFIT"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes (2)" width="90" x="179" y="255"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="NET_PROFIT|USER1|USER2|USER3|USER4|USER7|USER8|USER9|USER10|USER11|USER12|USER13|USER18|USER19|USER21|USER32|USER33|USER34|USER39|USER40|USER41|USER42|USER43|USER47|USER48|USER49|USER50|USER51|USER52|USER53|USER54|USER55|USER56"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="replace_missing_values" expanded="true" height="94" name="Replace Missing Values (2)" width="90" x="313" y="255"> <list key="columns"/> </operator> <operator activated="true" class="optimize_selection_evolutionary" expanded="true" height="94" name="Optimize Selection (Evolutionary)" width="90" x="246" y="30"> <parameter key="maximum_number_of_generations" value="20"/> <parameter key="parallelize_evaluation_process" value="true"/> <process expanded="true" height="758" width="882"> <operator activated="true" class="support_vector_machine" expanded="true" height="112" name="SVM (2)" width="90" x="246" y="75"> <parameter key="kernel_type" value="radial"/> <parameter key="max_iterations" value="100"/> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="447" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance (2)" width="90" x="673" y="64"/> <connect from_port="example set" to_op="SVM (2)" to_port="training set"/> <connect from_op="SVM (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="SVM (2)" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="select_by_weights" expanded="true" height="94" name="Select by Weights" width="90" x="380" y="30"/> <operator activated="true" class="support_vector_machine" expanded="true" height="112" name="SVM" width="90" x="514" y="30"> <parameter key="max_iterations" value="1000"/> </operator> <operator activated="true" class="read_database" expanded="true" height="60" name="Read Database (2)" width="90" x="45" y="435"> <parameter key="connection" value="DataWarehouse"/> <parameter key="query" value="blah"> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (3)" width="90" x="45" y="570"> <parameter key="name" value="NET_PROFIT"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes (3)" width="90" x="179" y="570"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="NET_PROFIT|USER1|USER2|USER3|USER4|USER7|USER8|USER9|USER10|USER11|USER12|USER13|USER18|USER19|USER21|USER32|USER33|USER34|USER39|USER40|USER41|USER42|USER43|USER47|USER48|USER49|USER50|USER51|USER52|USER53|USER54|USER55|USER56"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="replace_missing_values" expanded="true" height="94" name="Replace Missing Values (3)" width="90" x="313" y="570"> <list key="columns"/> </operator> <operator activated="true" class="select_by_weights" expanded="true" height="94" name="Select by Weights (2)" width="90" x="514" y="480"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="648" y="480"> <list key="application_parameters"/> </operator> <operator activated="true" class="create_formula" expanded="true" height="76" name="Create Formula" width="90" x="514" y="660"/> <operator activated="true" class="write" expanded="true" height="60" name="Write" width="90" x="740" y="624"> <parameter key="object_file" value="C:\formula.ioo"/> <parameter key="output_type" value="XML"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="648" y="255"/> <connect from_op="Read Database" from_port="output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Replace Missing Values (2)" to_port="example set input"/> <connect from_op="Replace Missing Values (2)" from_port="example set output" to_op="Optimize Selection (Evolutionary)" to_port="example set in"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="example set out" to_op="Select by Weights" to_port="example set input"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="weights" to_op="Select by Weights" to_port="weights"/> <connect from_op="Select by Weights" from_port="example set output" to_op="SVM" to_port="training set"/> <connect from_op="Select by Weights" from_port="weights" to_op="Select by Weights (2)" to_port="weights"/> <connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="SVM" from_port="weights" to_port="result 3"/> <connect from_op="Read Database (2)" from_port="output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Replace Missing Values (3)" to_port="example set input"/> <connect from_op="Replace Missing Values (3)" from_port="example set output" to_op="Select by Weights (2)" to_port="example set input"/> <connect from_op="Select by Weights (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_op="Create Formula" to_port="model"/> <connect from_op="Create Formula" from_port="formula" to_op="Write" to_port="object"/> <connect from_op="Create Formula" from_port="model" to_port="result 4"/> <connect from_op="Write" from_port="object" to_port="result 5"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> <portSpacing port="sink_result 6" spacing="0"/> </process> </operator></process>
