How to calculate volume (in m3) of closed surface?
thanks
If you use the VOlume Group Option By Volume Regions.
Then right click Info would give you volume of each volume region.
You can also request integrated element output, then you'll be able to track Volume for that element set in AcuProbe, acuTrans, etc.
