<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="341" width="815"> <operator activated="true" class="generate_nominal_data" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_values" value="10"/> </operator> <operator activated="true" class="replace" expanded="true" height="76" name="Insert |" width="90" x="246" y="75"> <parameter key="replace_what" value="value1"/> <parameter key="replace_by" value="val|ue1"/> </operator> <operator activated="true" class="replace" expanded="true" height="76" name="Insert @ width=90" x="380" y="75"> <parameter key="replace_what" value="value2"/> <parameter key="replace_by" value="@value2"/> </operator> <operator activated="true" class="replace" expanded="true" height="76" name="Replace | or @ width=90" x="581" y="120"> <parameter key="replace_what" value=".*@.*|.*\|.*"/> </operator> <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="715" y="165"> <parameter key="condition_class" value="no_missing_attributes"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Insert |" to_port="example set input"/> <connect from_op="Insert |" from_port="example set output" to_op="Insert @ to_port=example set input"/> <connect from_op="Insert @ from_port=example set output" to_op="Replace | or @ to_port=example set input"/> <connect from_op="Replace | or @ from_port=example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="198"/> <portSpacing port="sink_result 2" spacing="90"/> </process> </operator></process>
