# ClassificationAccuracy C ParameterNaN 0.03125
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource" activated="no"> <parameter key="attributes" value="C:\Documents and Settings\Lexusboy\My Documents\RapidMiner\Supervised\test_2_svm_negative_out_200_tf_idf.aml"/> </operator> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="random"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="parameter_string" value="label"/> <parameter key="attribute_name_regex" value="label"/> <parameter key="process_special_attributes" value="true"/> <operator name="BinDiscretization" class="BinDiscretization"> <parameter key="range_name_type" value="short"/> </operator> </operator> <operator name="GridParameterOptimization" class="GridParameterOptimization" expanded="yes"> <list key="parameters"> <parameter key="LibSVMLearner.C" value="0.03125,0.0625,0.125,0.25,0.5,1,2,4,8,16,32,64,128,256,512,1024,2048,4096,8192,16384,32768"/> </list> <operator name="XValidation" class="XValidation" expanded="no"> <parameter key="number_of_validations" value="5"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="C" value="32768"/> <list key="class_weights"> </list> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <parameter key="main_criterion" value="accuracy"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="true"/> <parameter key="weighted_mean_recall" value="true"/> <parameter key="weighted_mean_precision" value="true"/> <parameter key="absolute_error" value="true"/> <parameter key="relative_error" value="true"/> <list key="class_weights"> </list> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <parameter key="filename" value="C:\Documents and Settings\Lexusboy\My Documents\RapidMiner\Supervised\processLog.log"/> <list key="log"> <parameter key="ClassificationAccuracy" value="operator.ClassificationPerformance.value.accuracy"/> <parameter key="C Parameter" value="operator.LibSVMLearner.parameter.C"/> </list> <parameter key="persistent" value="true"/> </operator> </operator> <operator name="ParameterSetWriter" class="ParameterSetWriter"> <parameter key="parameter_file" value="C:\Documents and Settings\Lexusboy\My Documents\RapidMiner\Supervised\gridParameters.par"/> </operator></operator>
