time series dataset labeling around positive instance
wessel
I have an animal dataset which contains a time series.
At some point in time an animal is flagged ill.
But an animal is also ill before and after this time point.
What filter can I use to add a positive label to instances before and after time points flagged ill?
Wessel
Time Series
TobiasMalbrecht
Hello Wessel,
well, this one is not trival though. Is the flag indicating illness a nominal attribute?
A first (potentially working ;-)) solution to that problem might be to define the illness incident as a peak of a time series (e.g. by marking that point as 1 in contrast to a series of zeros) and to extract the index of that peak using the series extension. You could then define this index as a macro and use this one to set the illness flag using the [tt]Set Data[/tt] operator around that index.
A second solution should be to write a script to extract the same index and to set illness flag of the examples around that index.
Hope that gives you a hint,
Tobias
