Hi all,
How can I insert tabular data into boundary condition?
E.g: temperature at inflow with flow rate of 100 metre cube/hr; (transient):
time (s) temperature (K)
0 300
10 290
20 280
30 270
Thanks & regards
alpharays
One way to do that is using a multiplier function (Type = Piecewise linear) with curve fit variable = Time.
Then insert the table in Curve Fit values.
Under Simple Boundary Conditions, give Temperature = 1K and multiplier function.
This will multiple 1K with the table you enter above.
Hopefully screenshot help-.
