<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="258" width="915"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="30" y="56"> <parameter key="repository_entry" value="Past_Deltas"/> </operator> <operator activated="true" class="nominal_to_date" expanded="true" height="76" name="Nominal to Date" width="90" x="179" y="30"> <parameter key="attribute_name" value="DateTime"/> <parameter key="date_type" value="date_time"/> <parameter key="date_format" value="yyyy-MM-dd hh:mm:ss.0"/> </operator> <operator activated="true" class="date_to_numerical" expanded="true" height="76" name="Date to Numerical" width="90" x="313" y="30"> <parameter key="attribute_name" value="DateTime"/> <parameter key="time_unit" value="minute"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="DateTime_minute = 15"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/> <connect from_op="Date to Numerical" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
