Sebastian Land wrote:Hi,I can confirm this problem. We will trace it down as soon as possible. Don't know why this occurs only on Windows 7.Greetings, Sebastian
Apr 22, 2010 9:14:49 AM INFO: Process startsApr 22, 2010 9:14:50 AM INFO: Execute Program: stderr:java version "1.6.0_18"Java(TM) SE Runtime Environment (build 1.6.0_18-b07)Java HotSpot(TM) Client VM (build 16.0-b13, mixed mode, sharing)Apr 22, 2010 9:14:50 AM INFO: Execute Program: stdout:Apr 22, 2010 9:14:50 AM INFO: Program exited succesfully.Apr 22, 2010 9:14:50 AM INFO: Saving results.Apr 22, 2010 9:14:50 AM INFO: Process finished successfully after 0 s
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="190" width="346"> <operator activated="true" class="execute_program" expanded="true" height="60" name="Execute Program" width="90" x="246" y="30"> <parameter key="command" value="cmd /c java -version"/> </operator> <operator activated="true" class="execute_program" expanded="true" height="60" name="Execute Program (2)" width="90" x="239" y="249"> <parameter key="command" value="cmd /c notepad"/> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
