CHAID ISSUE
B_Miner
New Altair Community Member
Getting an error on the CHAID model asking for relevance criteria. Is there any for this besides chisq?
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="287" width="346">
<operator activated="true" class="generate_direct_mailing_data" expanded="true" height="60" name="Generate Direct Mailing Data" width="90" x="31" y="54">
<parameter key="number_examples" value="10000"/>
<parameter key="use_local_random_seed" value="true"/>
<parameter key="local_random_seed" value="2010"/>
<operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="165">
<parameter key="attribute" value="name"/>
<parameter key="attributes" value="zip code|name"/>
<operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="246" y="30">
<process expanded="true" height="336" width="174">
<operator activated="true" class="chaid" expanded="true" height="76" name="CHAID" width="90" x="45" y="52"/>
<connect from_port="training" to_op="CHAID" to_port="training set"/>
<connect from_op="CHAID" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<process expanded="true" height="336" width="413">
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" expanded="true" height="76" name="Performance" width="90" x="246" y="75">
<parameter key="accuracy" value="true"/>
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Generate Direct Mailing Data" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</process>
I am having a different issue with CHAID.
It is supposed to be able to take numerical attributes, however when passed numerical attributes it says "Numerical attributes not supported."
-Gagi
0 -
Hi all,
booth issues should be fixed in the current version. So I would suggest dating up as soon as possible. The wrong meta data propagation will be available with version 005.
Greetings,
Sebastian0 -
So there is a newer version than 5.003?
-Gagi0 -
no there isn't but there will be
Greetings,
Sebastian0
