Dear All,
I want to modify the value of a parameter from my Java code. It seems I am missing something obvious because the modification is not applied.
In my case I want to modify the value of the "Attributes" parameter of the "Select Attributes" operator.
What is the good way for modifying the value of a parameter?
Thanks in advance for your help,
regards,
Aurelien.
import java.io.File;
import java.io.IOException;
import java.util.Collection;
import java.util.Iterator;
import com.rapidminer.RapidMiner;
import com.rapidminer.example.Attribute;
import com.rapidminer.example.Attributes;
import com.rapidminer.example.Example;
import com.rapidminer.example.ExampleReader;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorCreationException;
import com.rapidminer.operator.Value;
import com.rapidminer.operator.ValueDouble;
import com.rapidminer.operator.learner.igss.Result;
import com.rapidminer.tools.OperatorService;
import com.rapidminer.tools.XMLException;
import com.rapidminer.Process;
public class DescriptorModification {
// Change the subset of attributes for an existing process
public DescriptorModification(){
Process rmProcess;
RapidMiner.init();
try {
// Load an existing process
// The process contains a "Select Attributes" operator wichich select the subset "Att1|Att2"
rmProcess = new Process( new File( "MyProcess.rmp") );
// Change the subset of Attributes
Operator selectAttributesOperator = rmProcess.getOperator( "Select Attributes" );
selectAttributesOperator.setParameter("Attributes", "Att1|Att2|Att3|Att4");
// Check if the "Select Attributes" operator parameters were changed
// Yes, the display is: "Att1|Att2|Att3|Att4"
selectAttributesOperator= rmProcess.getOperator( "Select Attributes" );
System.out.println( selectAttributesOperator.getParameter("Attributes") );
// Check if the XML corresponding to the process is changed
// No, it is still the former attributes: "Att1|Att2"
System.out.print( rmProcess );
} catch (Exception e) {
e.printStackTrace();
public static void main(String[] args) {
DescriptorModification garm = new DescriptorModification();
Thanks
