<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="296" width="1018"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="three ring clusters"/> <parameter key="number_examples" value="1000"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="optimize_parameters_grid" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="204" y="27"> <list key="parameters"> <parameter key="Clustering.k" value="[2.0;12;13;linear]"/> </list> <process expanded="true" height="610" width="1073"> <operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="246" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="k_means" expanded="true" name="Clustering"> <parameter key="k" value="10"/> </operator> <connect from_port="training" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="model"/> <connect from_op="Clustering" from_port="clustered set" to_port="through 1"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="cluster_distance_performance" expanded="true" name="Performance"/> <connect from_port="model" to_op="Performance" to_port="cluster model"/> <connect from_port="test set" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
