<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="415" width="547"> <operator activated="true" class="text:process_document_from_file" expanded="true" height="76" name="Text Input" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="C1" value="C:\My Documents\Research\Corpus1"/> <parameter key="C2" value="C:\My Documents\Research\Corpus2"/> </list> <parameter key="create_word_vector" value="false"/> <parameter key="keep_text" value="true"/> <process expanded="true" height="401" width="437"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="text|label"/> </operator> <operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="380" y="30"> <parameter key="number_of_validations" value="2"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1"/> <process expanded="true" height="610" width="435"> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="45" y="30"> <list key="specify_weights"/> <process expanded="true" height="610" width="300"> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="180" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="singular_value_decomposition" expanded="true" height="94" name="SVD" width="90" x="180" y="30"> <parameter key="return_preprocessing_model" value="true"/> <parameter key="dimensions" value="100"/> </operator> <operator activated="true" class="support_vector_machine_libsvm" expanded="true" height="76" name="SVM" width="90" x="315" y="30"> <parameter key="kernel_type" value="linear"/> <list key="class_weights"/> <parameter key="shrinking" value="false"/> <parameter key="confidence_for_multiclass" value="false"/> </operator> <connect from_port="training" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="SVD" to_port="example set input"/> <connect from_op="Process Documents from Data" from_port="word list" to_port="through 2"/> <connect from_op="SVD" from_port="example set output" to_op="SVM" to_port="training set"/> <connect from_op="SVD" from_port="preprocessing model" to_port="through 1"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> <portSpacing port="sink_through 3" spacing="0"/> </process> <process expanded="true" height="610" width="435"> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="45" y="30"> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" expanded="true" name="Tokenize (2)"/> <operator activated="true" class="text:filter_stopwords_english" expanded="true" name="Filter Stopwords (2)"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply SVD Model" width="90" x="44" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply ML Model" width="90" x="179" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" expanded="true" height="76" name="Performance" width="90" x="45" y="300"> <parameter key="precision" value="true"/> <parameter key="recall" value="true"/> </operator> <connect from_port="model" to_op="Apply ML Model" to_port="model"/> <connect from_port="test set" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_port="through 1" to_op="Apply SVD Model" to_port="model"/> <connect from_port="through 2" to_op="Process Documents from Data (2)" to_port="word list"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Apply SVD Model" to_port="unlabelled data"/> <connect from_op="Apply SVD Model" from_port="labelled data" to_op="Apply ML Model" to_port="unlabelled data"/> <connect from_op="Apply ML Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="source_through 3" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Text Input" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
