Altair RISE
Nominate Yourself Now!
Parameter Optimzation Grid
User: "TheBear"
New Altair Community Member
Updated by Jocelyn
I was trying to test the features of RM5 during the weekend and I got something working which is intended to optimize
the parameters of a neural network for prediction. ( I used that Topic for an example comparing RM4 tree model with that I used in RM5  http://rapid-i.com/rapidforum/index.php/topic,615.msg2350.html#msg2350 )
First of all it should optimize Learning rate and Momentum for the MLP network.
If I choose a "strange" combination for grid range for the LR and M then it happens that the process halts stops during execution and error is thrown saying "Cannot reset network to a smaller learning rate". (I submitted for that already a bugreport)
BTW for the RBF network it works just fine!
1. It would be nice  to know, if I might picked up wrong combinations of parameter ranges (0.1-0.8 for both LR and M with 10 steps) that causes this error?
2. Can I optimize the number of neurons as well? (In the parameter wizard  the "hidden_layer" is grayed out)
3. I replace the missing values infront of the GridOptimization and not within the nested process. Rapid miner realizes that as error in the problemsTab at the bottom but it seems to work. Is that bad practice placing the preprocessing processes outside of the nested operators?
4. I havent quite understood how I can use the "optimized parameters" further. Where are these optimized parameters stored? and how can I access it? During the optimization the process does keep the "at this stage best" parameters for later use, doesnt it?
There exists a process SetParameters but only has an input node and no output. I tried to use the name_map feature there to map the parameters from the learner inside the optimization  process to an outside Learner but it seems not really to work. maybe I have not understood the concept behind it. Can someone explain that for Beginners?
Which model does the parameterOptimzation operator returns? The last model which has been evaluated (maxRange of parameter) or that one with the optimized parameters?
I am sorry to ask that but I am simply not clear with that.
Any answer is appreciated! Thanks in advance
<process version="5.0">
 <context>
   <input>
     <location/>
   </input>
   <output>
     <location/>
     <location/>
     <location/>
   </output>
   <macros/>
 </context>
 <operator activated="true" class="process" expanded="true" name="Process">
   <process expanded="true" height="558" width="913">
     <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="72" y="41">
       <parameter key="repository_entry" value="VoidsBGA2007"/>
     <operator activated="true" class="nominal_to_numerical" expanded="true" height="94" name="Nominal to Numerical" width="90" x="179" y="120"/>
     <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="255">
       <parameter key="attributes" value="BGA Standoff Soldered|BGA Standoff assembled|BGA Void mean|Solder paste|Soldering|Alloy compound|Wetting inner area mean|Wetting paste height"/>
     <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="112" y="435">
       <parameter key="condition_class" value="missing_labels"/>
       <parameter key="invert_filter" value="true"/>
     <operator activated="true" class="replace_missing_values" expanded="true" height="94" name="Replace Missing Values" width="90" x="246" y="435">
       <list key="columns"/>
     <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="380" y="435"/>
     <operator activated="true" class="optimize_parameters_grid" expanded="true" height="130" name="Optimize Parameters (Grid)" width="90" x="447" y="255">
       <list key="parameters">
         <parameter key="TrainBPNN local.learning_rate" value="[0.1;0.8;10;linear]"/>
         <parameter key="TrainBPNN local.momentum" value="[0.1;0.8;10;linear]"/>
       </list>
       <parameter key="parallelize_optimization_process" value="true"/>
       <process expanded="true" height="576" width="931">
         <operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="45" y="30">
           <parameter key="sampling_type" value="shuffled sampling"/>
           <process expanded="true" height="576" width="440">
             <operator activated="true" class="neural_net" expanded="true" height="76" name="TrainBPNN local" width="90" x="179" y="30">
               <list key="hidden_layers">
                 <parameter key="H1" value="20"/>
               </list>
               <parameter key="learning_rate" value="0.66"/>
               <parameter key="momentum" value="0.1"/>
             <connect from_port="training" to_op="TrainBPNN local" to_port="training set"/>
             <connect from_op="TrainBPNN local" from_port="model" to_port="model"/>
             <portSpacing port="source_training" spacing="0"/>
           </process>
             <operator activated="true" class="apply_model" expanded="true" height="76" name="testBPNN local" width="90" x="45" y="30">
             <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="268" y="30">
               <parameter key="use_example_weights" value="false"/>
             <connect from_port="model" to_op="testBPNN local" to_port="model"/>
             <connect from_port="test set" to_op="testBPNN local" to_port="unlabelled data"/>
             <connect from_op="testBPNN local" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
             <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
             <portSpacing port="sink_averagable 1" spacing="0"/>
             <portSpacing port="sink_averagable 2" spacing="0"/>
           </process>
         <connect from_port="input 1" to_op="Validation" to_port="training"/>
         <connect from_op="Validation" from_port="model" to_port="result 2"/>
         <connect from_op="Validation" from_port="training" to_port="result 1"/>
         <connect from_op="Validation" from_port="averagable 1" to_port="performance"/>
         <portSpacing port="sink_performance" spacing="0"/>
       </process>
     <operator activated="true" class="set_parameters" expanded="true" height="60" name="Set Parameters" width="90" x="514" y="120">
       <list key="name_map">
         <parameter key="testBPNN local" value="BPNN Opt"/>
       </list>
     <operator activated="true" class="neural_net" expanded="true" height="76" name="BPNN Opt" width="90" x="715" y="435">
         <parameter key="H1" value="5"/>
       </list>
     <connect from_op="Retrieve" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/>
     <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
     <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
     <connect from_op="Filter Examples" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
     <connect from_op="Replace Missing Values" from_port="example set output" to_op="Multiply" to_port="input"/>
     <connect from_op="Multiply" from_port="output 1" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
     <connect from_op="Multiply" from_port="output 2" to_op="BPNN Opt" to_port="training set"/>
     <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/>
     <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_op="Set Parameters" to_port="parameter set"/>
     <connect from_op="BPNN Opt" from_port="model" to_port="result 2"/>
   </process>
</process>
PS: I read the related topic here
http://rapid-i.com/rapidforum/index.php/topic,1279.msg4911.html#msg4911
1 - 2 of 21
    User: "B_Miner"
    I am curious about this - if you had any resolution. I have not experienced the 'halting' issue but was trying to optimize the number of hidden units and the that greyed out as u did.
    User: "land"
    giving in detail answers to all this questions would fill a complete webinar. I would suggest booking one, otherwise you will have to dig further with the hints I can give you in the limited time I have:
    1. Unfortunately I'm not familiar with the neural net implementation's parameter combination. You could anyway wrap the model into something like the handle exception operator to avoid crashing the complete optimization.
    2. You can, but since the values are stored inside a list, you cannot access them directly. I would use a set macro operator for defining a macro containing the number. Write this macro into the parameter list for the numbers. Finally let the optimization fill in different values into the value parameter of the set macro operator.
    3. If you do preprocessing that depends on the data like normalization, then it would be best to incorporate it into the validation. Otherwise you would use data inside a XValidation step, that's not available when you normally apply the model. In the normalization case it would be the same range for all data. But if you always replace missing values by 0, then it should not make a difference at all. How does it complain?
    4. You will receive an object containing the optimal parameter settings. If you forward this object to the Set Parameters operator, these settings will be extracted and the optimal values will be set to arbitrary operators. You can define as well the source as the target operator in the parameter map you encountered already.
    The optimization will return always the best model it ever encountered.
    I hope this helped although I had to cut it shortly...
    Greetings,
      Sebastian
