<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="595" width="366"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="98" y="74"/> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="75"> <list key="function_descriptions"> <parameter key="att1_new" value="if (att1 > 3, 0/0, att1)"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Example example = <get-example-from-anywhere>;example.setValue(<attribute>,Double.NaN);
