Altair RISE
Nominate Yourself Now!
RapidMiner does not load Text plugin
NickDM
I have installed the text plugin jar into RAPIDMINER_HOME/lib/plugins.
When I start Rapid Miner, I see in the Java console that it has not loaded the plugin because a problem with the jar manifest is occurred.
This is the dump of my Java Console.
Somebody can help me to solve this problem?
Thanks,
Nicola
RAPIDMINER_HOME is not set. Trying the directory 'C:\Programmi\Rapid-I\RapidMine
r5\scripts\..'...
Using local jre: C:\Programmi\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.exe...
Starting RapidMiner from 'C:\Programmi\Rapid-I\RapidMiner5\scripts\..' using cla
sses from 'C:\Programmi\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.jar'...
24-feb-2010 9.15.52 com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'C:\Programmi\Rapid-I\RapidMiner5\scripts\..'.
24-feb-2010 9.15.52 com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform WIN32
2010-02-24 09:15:53 CONFIG: Locale not specified explicitly. Set default locale
to US. (RapidMiner.init())
2010-02-24 09:15:53 INFO: rapidminer.home is 'C:\Programmi\Rapid-I\RapidMiner5\s
cripts\..'. (Launcher.ensureRapidMinerHomeSet())
2010-02-24 09:15:53 CONFIG: Reading configuration resource com/rapidminer/resour
ces/rapidminerrc. (ParameterService.loadAllRCFiles())
2010-02-24 09:15:53 CONFIG: Neither system property 'rapidminer.config.dir' nor
environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService
.getGlobalConfigDir())
2010-02-24 09:15:53 CONFIG: Trying rcfile 'C:\Documents and Settings\Nicola Gull
o\.RapidMiner5\5_0_3_rapidminerrc'...skipped (ParameterService.loadRCFile())
2010-02-24 09:15:53 CONFIG: Read rcfile 'C:\Documents and Settings\Nicola Gullo\
.RapidMiner5\5_0_3_rapidminerrc.Windows XP'. (ParameterService.loadRCFile())
2010-02-24 09:15:53 CONFIG: Trying rcfile 'C:\Programmi\Rapid-I\RapidMiner5\rapi
dminerrc.Windows XP'...skipped (ParameterService.loadRCFile())
2010-02-24 09:15:53 CONFIG: Property rapidminer.rcfile not specified...skipped (
2010-02-24 09:15:53 CONFIG: Read extension state. (ManagedExtension.readConfigur
ation())
2010-02-24 09:15:53 CONFIG: Scanning plugins in C:\Programmi\Rapid-I\RapidMiner5
\scripts\..\lib\plugins. (Plugin.initAll())
2010-02-24 09:15:53 WARNING: The jar file 'C:\Programmi\Rapid-I\RapidMiner5\scri
pts\..\lib\plugins\rapidminer-text-4.6.jar' does not contain an entry 'RapidMine
r-Type' in its manifest and will therefore not be loaded (if this file actually
is a plugin updating the plugin file might help). (Plugin.findPlugins())
2010-02-24 09:15:53 CONFIG: Loading renderers from 'Text Processing'. (RendererS
ervice.init())
2010-02-24 09:15:53 CONFIG: Reading parse rules from jar:file:C:\Documents and S
ettings\Nicola Gullo\.RapidMiner5\managed\rmx_text-5.0.2.jar!/com/rapidminer/res
ources/parserulesTextProcessing.xml (XMLImporter.importParseRules())
2010-02-24 09:15:53 CONFIG: Loading operators from 'OperatorsCore.xml'. (Operato
rService.registerOperators())
2010-02-24 09:15:53 CONFIG: Loading operator documentation from jar:file:/C:/Pro
grammi/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/i18n/Ope
ratorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())
2010-02-24 09:15:54 CONFIG: Loading operators from 'C:\Documents and Settings\Ni
cola Gullo\.RapidMiner5\managed\rmx_text-5.0.2.jar'. (OperatorService.registerOp
erators())
2010-02-24 09:15:54 CONFIG: Loading operator documentation from jar:file:C:\Docu
ments and Settings\Nicola Gullo\.RapidMiner5\managed\rmx_text-5.0.2.jar!/com/rap
idminer/resources/i18n/OperatorsDocTextProcessing.xml. (OperatorDocBundle$XMLCon
trol.newBundle())
2010-02-24 09:15:54 CONFIG: Number of registered operator classes: 429; number o
f registered operator descriptions: 430; number of replacements: 431 (OperatorSe
rvice.init())
2010-02-24 09:15:54 CONFIG: Loading operator usage statistics. (UsageStatistics.
load())
2010-02-24 09:15:54 CONFIG: Reading parse rules from jar:file:/C:/Programmi/Rapi
d-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/parserules.xml (XML
2010-02-24 09:15:54 CONFIG: Loading repositories from C:\Documents and Settings\
Nicola Gullo\.RapidMiner5\repositories.xml (RepositoryManager.load())
2010-02-24 09:15:54 CONFIG: Adding repository TestRepository (RepositoryManager.
addRepository())
2010-02-24 09:15:54 CONFIG: Loading JDBC driver information from 'resource jdbc_
properties.xml'. (DatabaseService.loadJDBCProperties())
2010-02-24 09:15:54 CONFIG: Loaded JDBC driver com.mysql.jdbc.Driver (JDBCProper
ties.registerDrivers())
2010-02-24 09:15:54 CONFIG: Loaded JDBC driver org.postgresql.Driver (JDBCProper
2010-02-24 09:15:54 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver
(JDBCProperties.registerDrivers())
2010-02-24 09:15:54 CONFIG: Loaded JDBC driver org.hsqldb.jdbcDriver (JDBCProper
2010-02-24 09:15:54 WARNING: Missing database driver class name for 'ODBC Bridge
(e.g. Access)' (JDBCProperties.<init>())
2010-02-24 09:15:54 CONFIG: Loaded JDBC driver com.ingres.jdbc.IngresDriver (JDB
2010-02-24 09:15:54 CONFIG: Loaded JDBC driver ca.ingres.jdbc.IngresDriver (JDBC
2010-02-24 09:15:54 CONFIG: Neither system property 'rapidminer.config.dir' nor
2010-02-24 09:15:54 CONFIG: Loading renderers from 'file:/C:/Programmi/Rapid-I/R
apidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (Rendere
rService.init())
2010-02-24 09:15:54 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererSer
vice.init())
2010-02-24 09:15:55 CONFIG: Loading perspectives. (ApplicationPerspectives.loadA
ll())
2010-02-24 09:15:55 CONFIG: Ignoring update check. Last update check was on Tue
Feb 23 11:25:29 CET 2010 (UpdateManager.checkForUpdates())
land
RapidMiner 5.0 does not support the old plugins anymore. We have replaced them with improved versions using a new extension mechanism. Please use the integrated update function to install additional extensions. You can find it in the Help Menu under update RapidMiner.
Greetings,
Sebastian
sairagilani
installation not happens when i go to help and click for update installation of text mining
