dragoljub wrote:Hey Guys,Its great to see another update! When I select update to 5.03 it downloads and installs then says it must restart. After restarting I check the about for version info and it is not updated. If I launch the update manager again it will replete the entire process but the update is never applied.Interestingly all the extensions updated fine. Any Ideas?Running Windows 7 Ultimate 64 Bit.Thanks,-Gagi
dragoljub wrote:The update manager still shows the new version ready for update after the update goes through the install and restart process. Where can I check the files versions?The update should gray out once it is correctly applied.-Gagi
Sebastian Land wrote:But anyway I would recommend to download the new version from our website, since we have removed this error and added the capability to update the .exe file, too.
