Hi, all
I checked out Rapidminer from SVN (
https://yale.svn.sourceforge.net/svnroot/yale/Vega), built all source codes. Rapidminer can run successfully, but test suites can not be run via AllTests application with below errors:
There were 54 errors:
1) Sample '01_IO\01_ExampleSource.xml'(com.rapidminer.test.ExampleSetSampleTest)java.lang.Exception: File 'D:\workspace_dataminer\Rapidminer_Vega\sample\01_IO\01_ExampleSource.xml' does not exist!
at com.rapidminer.test.SampleTest.sampleTest(SampleTest.java:48)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at com.rapidminer.test.AllTests.main(AllTests.java:47)
2) Sample '01_IO\02_ArffExampleSource.xml'(com.rapidminer.test.ExampleSetSampleTest)java.lang.Exception: File 'D:\workspace_dataminer\myDM\sample\01_IO\02_ArffExampleSource.xml' does not exist!
It seems there is no 01_ExampleSource.xml under sample directory,so It can not be passed, I doubt it did not be executed after building successfully.
I found there are some sample under <home>\resources\com\rapidminer\resources\samples\processes directory, but the proccess file name is changed from .xml to .rmp. I do not know whether I can use these files to do testing?
Thanks you in advance for your help.
