Sebastian Land wrote:Hi,if each of your example is marked with the point in time, when the even occurs, you might use the Agglomerative Clustering with single link. If you only cluster on the time (mar each other attribute special or remove it), you will get a dendrogram, showing which events are combined into one cluster and which distance is between them.
