Hi everyone,
I have this issue trying to execute analysis with Ls-Dyna throughout Hyperstudy. I've registered Ls-Dyna.exe as a new solver execution script and I've added in the input arguments field "i={file}" in order to have my input file read by Hyperstudy. The problem is that when I check the model in the Test Models Tab I find the attached error related to license file.
I work with both network(server) licenses for Altair and Ls-Dyna. I normally run analysis in Ls-Run program. I also tried running radioss analysis through Hyperstudy and they're working too.
How can I overcome this issue with Ls-Dyna and Hyperstudy? Thank you!
