<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="449" width="346"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="multiply" expanded="true" height="112" name="Multiply" width="90" x="45" y="120"/> <operator activated="true" class="optimize_selection_evolutionary" expanded="true" height="94" name="Optimize Selection (Evolutionary)" width="90" x="179" y="300"> <process expanded="true"> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="optimize_selection_forward" expanded="true" height="94" name="Forward Selection" width="90" x="179" y="165"> <process expanded="true" height="489" width="782"> <operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="489" width="366"> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="489" width="366"> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="weight_by_relief" expanded="true" height="76" name="Weight by Relief" width="90" x="179" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Weight by Relief" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Forward Selection" to_port="example set"/> <connect from_op="Multiply" from_port="output 3" to_op="Optimize Selection (Evolutionary)" to_port="example set in"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="weights" to_port="result 3"/> <connect from_op="Forward Selection" from_port="attribute weights" to_port="result 2"/> <connect from_op="Weight by Relief" from_port="weights" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
