Reporting Example?
holger
New Altair Community Member
I've tried to work with the reporting extension, but it didn't work. I just retrieved some data from a rm-repository, connected it to a report-operator and connected the latter to a "generate report"-operator. Here's the process definition:
"No report was specified for this reporting operator."
What is wrong with my setup?
Best, Holger
<?xml version="1.0" encoding="UTF-8" standalone="no"?>However, when I run this basic process, I get the following error:
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="692" width="961">
<operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="112" y="390">
<parameter key="repository_entry" value="wellfields"/>
<operator activated="true" class="reporting:report" expanded="true" height="60" name="Report" width="90" x="246" y="390">
<parameter key="report_name" value="test-report"/>
<parameter key="report_item_header" value="test-header"/>
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="Data Table"/>
<parameter key="renderer_name" value="Meta Data View"/>
<list key="parameters">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="show_role" value="true"/>
<parameter key="show_table_index" value="true"/>
<parameter key="show_name" value="true"/>
<parameter key="show_construction" value="true"/>
<parameter key="show_type" value="true"/>
<parameter key="show_block" value="true"/>
<parameter key="show_statistics" value="true"/>
<parameter key="show_range" value="true"/>
<parameter key="show_sum" value="true"/>
<parameter key="show_missings" value="true"/>
</list>
<operator activated="true" class="reporting:generate_report" expanded="true" height="76" name="Generate Report" width="90" x="380" y="390">
<parameter key="report_name" value="test"/>
<parameter key="format" value="PDF"/>
<parameter key="pdf_output_file" value="test.pdf"/>
<parameter key="pdf_template_file" value="/Users/brandl/tdst.pdf"/>
<parameter key="image_template_file" value="no file selected"/>
<parameter key="section_one_font" value="courier"/>
<parameter key="section_two_font" value="courier"/>
<parameter key="section_three_font" value="courier"/>
<parameter key="section_four_font" value="courier"/>
<parameter key="section_five_font" value="courier"/>
<parameter key="text_content_font" value="courier"/>
<connect from_op="Retrieve" from_port="output" to_op="Report" to_port="reportable in"/>
<connect from_op="Report" from_port="reportable out" to_op="Generate Report" to_port="through 1"/>
</process>
</process>
Best, Holger
before one can add something to the report using the Report operator, you have to open a report using the Generate Report operator.
The name's really misleading, don't know why we have overseen it when we renamed the others.
Sorry for the inconvenience.
Greetings,
Sebastian0 -
Thanks for your answer.
Does this mean, that I have to connect all the examplesets which I would like to include into a report to the "Generate report" operator? How are inputs to it associated to "Report"-operators (which I assume to be connected to the outputs of the "Generate Report"-op)?
It seems ways more natural to me to connect data-sets to report-operators, which are consumed by a "generate report" node (which doesn't need any outgoing connections).
Where can I find any examples/documentation? Are the reporting operators already used in production, or are they still under development?
-Holger0 -
the reporting operators have been part of the Enterprise Edition for over a year now. That's the main reason, why we didn't change the behavior to be more 5.0 like: We couldn't break with compatibility for people paying us.
And no, the Report Generator just opens a Stream that's accessed by the subsequent Report operators via its name. To report things, you simply have to open a report using the Generator and add parts by the Report operator.
Unfortunately there are no samples right now.
Greetings,
Sebastian0
