<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="100" width="145"> <operator activated="true" class="generate_massive_data" expanded="true" height="60" name="Generate Massive Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1000"/> <parameter key="number_attributes" value="10"/> </operator> <operator activated="true" class="singular_value_decomposition" expanded="true" height="94" name="SVD" width="90" x="219" y="69"> <parameter key="return_preprocessing_model" value="true"/> </operator> <operator activated="true" class="write_model" expanded="true" height="60" name="Write Model" width="90" x="390" y="161"> <parameter key="model_file" value="C:\Documents and Settings\Owner\Desktop\out.mod"/> <parameter key="output_type" value="XML"/> </operator> <connect from_op="Generate Massive Data" from_port="output" to_op="SVD" to_port="example set input"/> <connect from_op="SVD" from_port="preprocessing model" to_op="Write Model" to_port="input"/> <connect from_op="Write Model" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
