Hi there,
I achieved to train a quite capable neural network and used the "Write Model" operator to save it.
Now I created a copy of the process and replaced the neural network training (2 operators: import data & neural net) by the "Read Model" operator.
Now I thought the output would be the same !
Strangely, the "Performance" operator behind the "Apply Model" operator now asks me to "insert apply model operator to add predictions". What is that ??
Kind Regards
Theo
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="564" width="840">
<operator activated="true" class="read_aml" expanded="true" height="60" name="Read AML (2)" width="90" x="45" y="120">
<parameter key="attributes" value="C:\Program Files\Rapid-I\RapidMiner5\tsresult"/>
<operator activated="true" class="read_model" expanded="true" height="60" name="Read Model" width="90" x="45" y="30">
<parameter key="model_file" value="C:\Documents and Settings\Theodor.Heinze\My Documents\RapidMinerRepository\poker\lastPokerModel2.mod"/>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="246" y="30">
<operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="380" y="30"/>
<connect from_op="Read AML (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Read Model" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Performance" from_port="performance" to_port="result 1"/>
</process>
</process>
