"No visualization available for object"
My problem:
I'm getting the following message when I double click on an object that is displayed in the Folder View of a cluster model: "No visualization available for object with id 1,020,793!". It is the same result for any item of the folder view.
What I'm trying to do
I'm trying to see if rapidminer can help in gathering voice of customer for my project.
I have 6000+ expert hotline articles (or "cases") to analyze.
I have structured my example set with 7 attributes:
- Case Type (Label, text)
- Product Name, Goals and symptoms, Facts and changes, Causes and fixes, Internal information (Regular, Text)
- Case ID (ID, Integer)
I have all that processed though a "Process Document from Data" operator with Wordstop, Tokenizer, etc... before going to Support Vector Clustering.
Once I get the clustured view of the data I want to be able to read the content of the attributes for each item. I should be able to do it by clicking inside the folder view?
Thanks for your help.
A.Moulart
