<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="422" width="567"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"/> <operator activated="true" class="execute_script" expanded="true" height="76" name="Execute Script" width="90" x="179" y="75"> <parameter key="script" value="operator.getProcess().getMacroHandler().addMacro("result", input[0].toResultString());"/> </operator> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="313" y="75"> <parameter key="macro_name" value="result"/> </operator> <operator activated="true" class="log" expanded="true" height="76" name="Log" width="90" x="447" y="75"> <list key="log"> <parameter key="result" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Execute Script" to_port="input 1"/> <connect from_op="Execute Script" from_port="output 1" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
